Latest post 11-08-2010 7:33 AM by StUrrock. 2 replies.
Page 1 of 1 (3 items)
  • 11-05-2010 9:16 AM
    • StUrrock
    • Top 500 Contributor
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    BeoVision 7 40"(MKii) Gefen 1.3 and ATV2 problem
    Hi Hope you may be able to help, Just have installed the following
    BeoVision 7 40"(MKii) AP SW 7.7
    Connected to a Gefen 1.3 switch (via DVI-i)socket
    Connected to Gefen;
    1. Sky HD
    2. Kaleidescape Mini player
    3.Apple TV 2
    Everything works beautifully except that when you select the ATV2 as a source it turns the beovision7 off?
    Has anybody else experience this.
    BTW do not like the concept of the new apple TV at all!!
  • 11-05-2010 12:41 PM In reply to
    Re: BeoVision 7 40"(MKii) Gefen 1.3 and ATV2 problem
    I have had similar problems on ATV2 with a bevision 7 32" mk3...   It appears to be an HDMI handshake problem. To fix it I had to power off the TV and the ATV, power back on the TV to the DVI port then power up the ATV.
    I have since tried changing the HDMI-DVI cable to a belkin one and turned of the sleep mode in ATV. One of these seems to have made a difference as it hasn't happened again for some time!
  • 11-08-2010 7:33 AM In reply to
    • StUrrock
    • Cambridgeshire
    • Posts 219
    Thanks Warren will give it a go!!
