Hi guys,
This is doing my head in, so any help you can give would be much appreciated!
I bought a Beo4 at the weekend. Since it's meant to be intuitive, i tried to control my ceiling speakers through my Beolink Passive using my Beo4.
Before using my Beo4, the Beolink Passive on the wall used to have a red light on, on the play button. If i pressed the play button the radio would play and the light would go off, pressing the play button again stopped the radio and the light would come back on.
Since trying to use my Be04, the light has permanently gone off of three of my Beolink passives. These were the three i manually pressed the play button on, to see if music was coming out of.
Last night, i set the timer on my Beolink passives, hoping they would all play music at the time i have set on my Beosound 3000. The only Beolink passive i have which i didn't press play on when i was fiddling with my Beo4, is the only one that the music came out of.
In short, how do i get my Beolink passives to work again?
The only B&O products i have in my house are the lights, the Beosound 3000 (which does not have its own speakers and is only linked up to the Beolink passive speakers in other rooms). I am confused by the various buttons on the Beo4. Do i just need to use the radio function to operate my Beosound 3000 or should i use a different setting? I also cannot get it to operater my lights! I managed to get it to operate my Beosound 3000 last night, but after more fiddling, it stopped doing that too.
Please help. I am hooribly confused.
Many thanks for taking the time and effort to help me.
Marc
