Hi Im using a control4 app on my ipad to control my B&O now the only prob is I havent got the hx codes for the tv command and the A.aux command off the beo4.
does anyone know them??
regards
Chris
The Beo4 HEX code for TV is 0x80 which is decimal 128
The HEX code for A.AUX is 0x83 which is decimal 131
Regards Keith....
Thank you very much
