Latest post 10-27-2010 2:33 AM by kallasr. 4 replies.
Page 1 of 1 (5 items)
  • 10-26-2010 1:30 PM
    • kpcvlp
    • Not Ranked
    • Joined on 05-09-2007
    • Posts 6
    remote cable
    could someone please tell me what the cable is called that plugs in to my beovision 5 with a little eye thing at the other end taped to my sky box, so that I can use the beo4 to control sky box.
    Its just when the sky man pulled it of the old box he broke a wire . I have tried to solder it but have given up.
    also do you have to go to b & o to get one or can you get a universal one from maplin
    cheers colin
  • 10-26-2010 3:50 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: remote cable
    I think it's simply called an IR remote sensor cable - as you called it in your post. I have one somewhere doing nothing.
    Chris.
  • 10-26-2010 3:59 PM In reply to
    • kpcvlp
    • Not Ranked
    • Posts 6
    Re: remote cable
    Hi Chris
    thanks for that
    did you want to sell it to me if so let me know how much. I can pay via paypal
    cheers colin
  • 10-26-2010 4:26 PM In reply to
    Re: remote cable
    kpcvlp:
    Did you resolder the broken wire itself, or did you use a new connector/jacket?
    Mind the polarity from the ir-eye. You can't just resolder the wire without checking the polarity.
    If you use a new connector, then the chassis is ground (-) and the little top is the positive lead (+). -> STB/DTV
    If you re using a 3,5mm stereo jacket, then the middle ring is the positive lead for STB/VAUX.
    So if your soldering doesnt work, try to resolder the wire and switch both leads. It will not damage your BV5 by switching the leads.
    It works or it works not, its that simple.
  • 10-27-2010 2:33 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: remote cable
    You can buy a standard ir cable to the job. I got one from ebay for appr. 8$ incl. shipping.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
