Hi Mikko,
Check the wiring between the boards 14 and 15 (Filters in the bottom). Bad junctions could cause this behaviour.
If you are able, then check resistor R1. This one might (almost) be burnt to death. (And so almost a great resistance is measured instead of a few 3.3 ohms)
I also would consider/advice to replace all the capacitors on both the filterboards.
Its a small investment, but the reward afterwards is great.
