Latest post 10-13-2010 12:09 PM by m96jlh. 2 replies.
Page 1 of 1 (3 items)
  • 10-07-2010 5:08 AM
    • m96jlh
    • Not Ranked
    • Joined on 10-25-2008
    • Posts 3
    Beocom 2 keeps reverting to 'clock has not been set' status
    Hello
    My Beocom 2 keeps reverting to 'clock has not been set' status.  At which point I reset the clock, date etc and then it may work again for a while before it reverts again.  Please help!
    Filed under:
  • 10-12-2010 12:36 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Beocom 2 keeps reverting to 'clock has not been set' status
    I don't know! However, I have found THIS thread with similar problems. If you get no other replies to this then it may be worth contacting Kingstreet if you're within reach of them or emailing the other person that had the same problem.
    If you find out the problem, please do tell us on here to assist anyone else that experiences the same.
    SteveSmile
    If you think nobody cares, try missing a couple of payments.
  • 10-13-2010 12:09 PM In reply to
    • m96jlh
    • Not Ranked
    • Posts 3
    Thanks for this - I may try to see if i can get the batteries updated in the first instance.
