Latest post 10-06-2010 12:57 PM by Medogsfat. 12 replies.
Page 1 of 1 (13 items)
  • 10-02-2010 3:58 PM
    Repair on a Master Control Panel 5500....?
    Could anyone point me in the right direction, toward someone with technical ability who could possibly have a go at repairing the rotary volume control dial on a MCP5500.
    The unit itself is in pretty good shape, and every other function seems to work fine.
    Shame then that the rotary dial (which is not split or broken like many) is simply not raising/lowering the volume as it should.
    If there is anyone (preferably in the UK) that has the knowledge to repair this, please let me know. If necessary, I will consider sending it overseas if no-one in the UK is recommended.
    Many thanks all.
    Michael
    Michael
    BV5, BV Avant, MX4000, MX1500
    BS 7000, BS 5500
    Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
    BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
  • 10-02-2010 4:58 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Repair on a Master Control Panel 5500....?
    Sounds like the microswitch has gone. Seen a few posts about this over the years. Not a hard job to replace it yourself from what I understand.
    CraigSmile
  • 10-03-2010 6:15 AM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    If the MCP does NOT light up when the wheel is rotated, the microswitch is bad.
    If the MCP lights up when you rotate the wheel but the volume does not change, the microswitch is OK
    and the optical reader is bad (I have a few NOS optos).
  • 10-03-2010 6:34 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    I have a replacement microswitch. It may just need the contacts cleaning though if this is the fault.
    Chris.
  • 10-03-2010 7:04 AM In reply to
    Dillen:
    Oh thank you very much, the MCP does NOT light up when the wheel is rotated. Therefore I guess I'm needing the new microswitch then.
    When coming to do that replacement, do I need to refer to the service manual I wonder? Or maybe you guys could talk me through what I need to do..
    ...if this job needs soldering or the use of any technical equipment I'm not able to do that & would be looking to send it off to someone in that case.
    Thanks for your helpful assistance.
    Michael
    BS 7000, BS 5500
  • 10-03-2010 7:11 AM In reply to
    Medogsfat:
    Chris.
    Hello Chris,
    Many thanks for your help. According to advice given on this thread, it sounds like the microswitch is what I need (or maybe just cleaning as you say) as the MCP doesnt light up on moving the dial.
    Is the microswitch an easy job for someone with no technical ability at all, like me..? Would I need to get hold of the service manual, or perform any soldering to replace this switch?
    And if you have a microswitch or sale, please let me have the details.
    If you do these types of repairs yourself (i remember talking to you about re-covering Penta frets i think!) please let me know if I could send the MCP up to you for attention.
    Michael
    Michael
    BS 7000, BS 5500
  • 10-03-2010 7:39 AM In reply to
    • Dillen
    • Posts 5,008
    Are the other functions of the MCP working ?
  • 10-03-2010 7:41 AM In reply to
    Dillen:
    Hi Martin,
    Yes, all other functions seem to be working just fine.
    Michael
    Michael
    BS 7000, BS 5500
  • 10-03-2010 8:16 AM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    I got an almost free MCP5500 (aluminium with ugly spots of some kind of glue and broken hinges but otherwise great condition) some weeks ago, with original box.
    I have opened it and tried to clean (first with contact cleaner, later with fine sand-paper) the microswitch but it's still working randomly. Sometimes it works flawlessly and sometimes it doesn't work at all (I have to rotate the dial up and down until it starts working).
    The switch has a socketed cable so if you can get a replacement, it's very easy to replace. Here is a close-up of the mechanism:
    Bang & Olufsen - The art of controlling sound, picture and light
  • 10-03-2010 8:25 AM In reply to
    lausvi:
    Oh thanks for that Sir,
    So its just a simple 'plug-out the old' and 'plug in the new' type situation?
    well, if it's really as easy as that perhaps even I could do itBig Smile , so Chris or anyone else who may have a spare switch please could you leave details for me.
    Many thanks for all the advice
    Michael
    Michael
    BS 7000, BS 5500
  • 10-03-2010 8:50 AM In reply to
    • Medogsfat
    • Posts 4,045
    I can change the switch no problem Michael.
    I'm in Leeds.
    Chris.
  • 10-03-2010 10:34 AM In reply to
    Medogsfat:
    I'm in Leeds.
    Chris.
    Smile Oh cheers Chris,
    Could you give me an estimation of your charge & send me your postal address please. I'll get it off to you shortly by recorded or special deliverySmile
    Many thanks,
    Michael
    Michael
    BS 7000, BS 5500
  • 10-06-2010 12:57 PM In reply to
    • Medogsfat
    • Posts 4,045
    You have a PM Michael.
    Chris.
