Latest post 10-04-2010 4:21 PM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 10-04-2010 1:40 PM
    • Relaximus
    • Not Ranked
    • Joined on 10-04-2010
    • Canton CT - USA
    • Posts 13
    Beogram 3300 Arm Problem
    My recently acquired Beogram 3300 has a problem with the arm system.  At rest, the arms are not parallel to the deck.  They are both higher at the cartridge end.  The result is that the cartridge will not track properly as it is not in full contact with the record surface.  Any ideas on how to level the arm assembly?
    B&O 3300
    Cheers!
    Dave
    New to B&O, but am now hooked!
    Beogram 3300 & RX2 - Consoles: '56 Fisher Custom Futura & '63 Custom Electra - '58, 2 x '61 & '63 Motorola's - '61 Grundig;  Assorted newer, silver-faced stuff
    Filed under:
  • 10-04-2010 2:57 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beogram 3300 Arm Problem
    1st thing to check is that all 3 transport screws (underneath the deck) are fully released.
    Chris.
  • 10-04-2010 3:58 PM In reply to
    • Relaximus
    • Not Ranked
    • Canton CT - USA
    • Posts 13
    Herein lies part of the problem:  The person I purchased it from did not engage the transport screws prior to packing and shipment.  I fear something may have gotten tweaked in transport.  The chassis seems to be floating fully and level.
    Dave
  • 10-04-2010 4:21 PM In reply to
    I have attmpted to answer in the Beogram section.
    @Mods  I suggest this is moved as it is a duplicate
    Regards Graham
