Latest post 08-29-2007 3:17 PM by Emme. 5 replies.
Page 1 of 1 (6 items)
  • 06-30-2007 9:34 AM
    • Emme
    • Not Ranked
    • Joined on 06-30-2007
    • Posts 2
    Beovision avant built-in video player
    Recently moved house and the video player no longer works just a white screen.  When looking through the user and set up guide the diagram showing therear socket panel shows a decoder, AV  and  blank area for the V. Tape when I look at the rear of my tv under the space marked V Tape there is  actually a socket for the connection of the built in video recorder but nothing is pluggede in or linked..  I wonder is something meant to plugged in this socket - did it fall out/off during the move?  Any tips greeatly appreciated.
  • 06-30-2007 9:51 AM In reply to
    Re: Beovision avant built-in video player
    Just spoken to an expert I know (!) and there should be a short lead coming out of the Avant that plugs into this socket. It is normally held in by a couple of clips.
  • 06-30-2007 9:53 AM In reply to
    Yes yuo need a scart cable from AV on VCR to V-TAPE on TV.
  • 06-30-2007 9:54 AM In reply to
    welcome to beoworld,Big Smile
    there should be a short scart lead from the "V-TAPE" scart socket to the first of 2 scart sockets located just above the round floor stand at the rear, not sure if it needs to be a special scart lead or if any replament will do, im sure one of the guys on here will know for sure
    jaySmile
    jason
  • 06-30-2007 10:49 AM In reply to
    No just a full mounted cable = 1,2 cm in diameter
  • 08-29-2007 3:17 PM In reply to
    • Emme
    • Not Ranked
    • Posts 2
    sorry for taking so long to reply but computer crashed and only just got it back.  Have connected a scart as suggested and hey presto the video is working again.  thanks for all your replies.
