1st March February 2012
Latest post 09-30-2010 2:41 AM by Spiros. 16 replies.
09-25-2010 5:03 PM
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Just got myself a Beolink converter. The sticker on the housing is missing so no idea what type it is.
One side the Masterlink and the other the AC, Powerlink and Audio Aux link connectors.
Is this automatically a T1611 unit or can it be something else? Please advise, thanks!
Leslie
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Re: Beolink converter type?
Leslie, as far as I know they all look the same externally. So not sure how you can tell the difference.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Leslie
- Netherlands
- Posts 2,201
Craig, you mean the connectors from all units on the outside have ML and PL/Audio Aux connectors?
Spiros, would you dare to try this experiment?[:'(]
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
HiI have both types, but cannot get at them to check - however in earlier posts mention was made of compatibility issues - I did NOT encounter these issues and both types worked happily with my setups!
I do have an issue with one currently in a BS4 / MX7000 system in that the box does not work as prescribed ie an internal software problem of which Vienna has informed Struer, so maybe in the future a resolution may surface - I have my doubts as the tv is older technology and I do not know if the same problem exists when used in a BS4 / newer tv system.
I did however sort a work around which seems to work(not ideally but there you go!)
My solution as with Spiros - GO FOR IT!
Hope this helps
Tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
Spiros:.............Silence of the Lamps!!!!!!!!!!! Something scary must have happened with the experiment!!
You mean 'Lambs'?
My B&O: 2009 Catalogue and Pricelist
Leslie
- Netherlands
- Posts 2,201
Must be the Greek version of this movie...
Leslie
- Netherlands
- Posts 2,201
No comments would be the best....
Leslie
- Netherlands
- Posts 2,201
Your help is much appreciated Spiros but your remark later was not understood. That's what you get with different cultures and mis-interpretation in language like "mate" etc. Please accept my apologies in front of all the Beoworld readers.
Leslie
Leslie
- Netherlands
- Posts 2,201
Thanks "mate"
Σας ευχαριστώ, είστε οι καλύτεροι
Jonathan
- Posts 1,164
Spiros:You know, I tried to help at the beggining but one thing I hate is irony and I didn't start this.
Sorry Spiros. Your english is excellent, I was just trying to be funny.....
Page 1 of 1 (17 items)
