Latest post 09-23-2010 5:53 AM by tournedos. 3 replies.
Page 1 of 1 (4 items)
  • 09-23-2010 5:33 AM
    • Bundy
    • Not Ranked
    • Joined on 05-25-2008
    • Bolderslev, Denmark
    • Posts 58
    • Gold Member
    Wich MMC to retip at Alex
    Hi
    Well I got a Beogram 4000 with a MMC4000 and it actualy works fine. The only thing is that the sound is lacking at little discant.  I am therefore thinking of getting Alex to retip it. I also have a MMC20s lying around, and the question is wich one should go to Alex. An other question is what kind of retipping I should get, keep it as orignal as possible or an upgrade.
    The final possibility is to wait until a MMC20CL turns up, who everyone praises to the skies.
    Any thoughts?
    Mogens
  • 09-23-2010 5:41 AM In reply to
    Re: Wich MMC to retip at Alex
    For 159 euros you can get a retipping that is equivalent to MMC20CL. I am very fond of my retipped MMC2 with the same option Smile
    The treble response can be a little bad on a 30+ year old cartridge, and an original MMC20CL may be bad as well. The suspension hardens inside the cartridge, plus an eventual worn cantilever which probably is the issue here.
    -Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 09-23-2010 5:49 AM In reply to
    • Bundy
    • Not Ranked
    • Posts 58
    • Gold Member
    Hej Søren
    Is that the MMC4000 I can get retipped to be an equivalent to a MMC20CL or the MMC20S?
    Mogens
  • 09-23-2010 5:53 AM In reply to
    Purely on the looks, I'd choose the MMC4000 over the black 20S. On the other hand it would be a shame to retip a cartridge that still gives decent service.
    I believe these cartridges have very little (if any) internal differences, so if you have the 20S retipped, I'd upgrade the stylus and you'll essentially have a better cartridge model. A BG4000 deserves more than the base spherical 20S.
    If you find a 20CL, you would probably need to have it retipped - or more properly, resuspensioned - right away as well unless you are extremely lucky... In this view, a 20EN would be a good alternative (also coloured silver).
    -mika
