Latest post 09-16-2010 3:30 PM by lano. 2 replies.
Page 1 of 1 (3 items)
  • 09-13-2010 5:14 PM
    • lano
    • Not Ranked
    • Joined on 04-25-2010
    • Posts 66
    • Gold Member
    In-wall speakers in surround set-up
    Hi, I going to set-up a surround system that will be based on a Beosystem 1 and have some questions that I hope you can help me with.
    The room is not very big (5,5 x 5,5 meters) and the system will only be used to watch TV (mainly sports and movies).
    As front speakers I will use Beolab 6000 (wall mounted). For rear and center speakers I planned to use Linn in-wall speaker 104C-S since I already have three of these left over.
    Question: Will this be a bad combination, sound wise? If so, is that valid for both rear and center and what other suggestion do you have?
    If I would use these speakers I plan to use a MCL2P or Beolink passive to drive the rear speakers.
    Question: Does the Beosystem 1 output both left and right channel on both "rear sockets" (so that I only can use one powerlink cable to the Beolink amplifier)?
    For the front speaker I would need some kind of amplifier also.
    Question: Does anybody have any suggestions here?
    Many thanks/lano
  • 09-15-2010 9:22 AM In reply to
    Re: In-wall speakers in surround set-up
    I have been fiddling recently with a very similar project using MCL2P's and passive speakers ...both in-wall and wall mount in a room about the same size.
    It is very much a work in progress and may actually be moved yet again! Laughing
    I only have the centers and fronts hooked up currently and will probably not go any further until I decide on its final resting place.
    Currently...
    BS1 > BV4
    Center: (1) PL cable to an MCL2P / (2) leads out to a pair of Anthony Gallo Nucleus speakers (in-wall socket mount).
    Fronts: (1) PL cable to an MCL2P / (2) leads out to a pair of BeoVox 3000 passive panels (wall mounted).
    Because all the speakers are passive, they seem to have a common warmth to them. I had to balance the distances in the menu to accomodate for the sizing of the speakers. The result has been very good.
    I had considered moving a pair of BL4000 or BL3000 (problem is the displays are bothersome for TV viewing -I think they are better for a link room) into the front position as the actives are just so brilliantly "clear". I would then find myself in a situation more like you -a mix of passive and actives. Personally, I think that it might make more sense to have the actives in the center... providing nice crystal clear dialogue and then have passives as the fronts where you can pick up some bass. With 6000's that probably isn't an option for you. In your case, I might even considering looking for a single or pair of BL4000 for the center??? and using the passives for the rear.
    Regardless, I think balancing the warmth of the passives w/ the clinical clarity of the active speakers might be a challenge. I am sure someone has a similar setup w/ mixed speakers here!
    If you move forward w/ your plans as they currently are... I'd suggest concentrating on the centers for now. Before cutting into the wall, set them up on a box or something at their finish placement level/position and play w/ the balance of the speakers. Spend some time listening. If you are happy w/ the results... keep in mind that once in the wall -the sound will improve. Then move on to the rears.
    Yes. As above, I have single PL leads from the audio outputs on the BS1.
    • B&o bottle opener
  • 09-16-2010 3:30 PM In reply to
    • lano
    • Not Ranked
    • Posts 66
    • Gold Member
    Thanks a lot for the input, very appreciated!
    I am also a bit concerned about mixing active and passives at the front. I do not think that it will be any problems with the rears (any one with experience?). At the moment I do not have an amplifier but I have just purchased one so I will soon be able to start testing.
    I do not really like the looks of having a Beolab 4000 as center speaker, especially not with Beolab 6000 as fronts, and do I really need to have two speakers as center, isn’t it only mono sound on the center channel?
    One other possible solution is to use a Beolab 3500 with this kit, it would probably match the Beolab 6000 better both sound wise and esthetical.
    Other suggestions for the center are very welcome.
    Regards/lano
