I have BS3200 and BM/BS5. BS3200 is the audio master. In a link system, the two systems work complimentary, i.e. n.music is possible without any flaws. Not sure when you add the BS9000, however, most likely you will need to set either BS9000 or BS3200 as audiomaster.
