Hello,
Any advise on the following issue.
I have the above combination. Its quite awesome with the tuner operating. Ive connected an NAD , CD Player to it and the quality drops off, dramatically, so does the max volume.
Can anyone help with this?..could it be a component matching issue eg CD player input characteristics ?..
Im probably going to find an B&O CD player , if thats the solution. The NAD CD player is quite a high quality unit.
Thanks for any tips on why this would happen .
Regards
Michael
