Latest post 11-13-2010 6:12 AM by Stoobietoo. 2 replies.
Page 1 of 1 (3 items)
  • 11-12-2010 4:26 PM
    BeoVision-5 and Beolink Passive (in same room)
    I would like to use my BV5 with Beolink Passive driving my BeoVox Pentas in the same room. This is a temporary set-up until I get some active speakers in the new year.
    So far I have connected up the BV5 and BL Passive with the Beolink Passinve & speakers using Materlink cable. It works but there is a delay between the BV5 speaker and the BL Passive.
    The  other issue is which option to use. (not sure which I'm on at the moment) but to turn on & off I have to have LINK showing in the Beo4, so if I'm watching DTV or DVD then I can control the speakers, but if I want to use my AppleTV which is is controlle using V-Aux I cannot as I have to have LINK showing and then if I go to V-Aux the speakers stay on the DTV. (Update - added the L-V-Aux button and can now control this correctly)
    Is it possible to get this working or am I wasting my time! I did read one post where someone said the powerlink socket can be used. ie it makes the speaker "active" in that you plug in a powerlink cable from the BV5 to the BL Passive and you don't use a Masterlink cable and don't need any link eye and it comes on when you use the BV5.
    Does that work? I don't want to put anything in that link socket on the BL Passive as the manual says not to. I tried the Config software available on here but it doesn't seem to have Beolink Passive in the Main room.
    Stoobie
  • 11-12-2010 11:30 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: BeoVision-5 and Beolink Passive (in same room)
    Easiest thing in the world.  You're over thinking this.  I assume that you're using the Pentas as front speakers.  First, get yourself a fully wired Powelink cable.  Then disconnect the MasterLink cable, and the IR cable to the passive kit.  Connect the kit to the BV-5 via the aforementioned PowerLink cable to one of the Front sockets on the BV-5.  Go to the appropriate menu on the BV-5 and tell it htat there are BEoLab Pentas attached.  The rest should be easy.
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 11-13-2010 6:12 AM In reply to
    Russ,
    I'm a lawyer - overthinking is in my blood Big Smile
    That worked, made sense and was so easy!!! Thanks
    Stoobie
