Latest post 08-19-2010 6:34 AM by BenSA. 1 replies.
Page 1 of 1 (2 items)
  • 08-17-2010 11:03 PM
    replacement panel for beogram cd 4500
    hi, I bought a beogram cd 4500 at a yard sale the other day. it had a big dent in the center of the silver drive cover and broken glass front panel. he told me it happened during a move. I tested all the functions and it works flawlessly. Can this panel be ordered from somewhere or am I sol?  also whats the best way of removing the silver cover so I can see if I can bang out that dent.
  • 08-19-2010 6:34 AM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Re: replacement panel for beogram cd 4500
    I can tell you that the glass panel is no longer available from B&O....so you would have to find a donor unit which is very difficult to find as most of them are still in working order and therefore the cost of buying the unit just for the glass would be high. Not sure about the silver panel, but without the glass its pointless trying to fix the silver panel. Sorry Sad
    Durban South Africa
