DrDimitris:
As far as I know there is no internal DVB HD for BV7-32 MK I and. II. If this is not the case I would be more than happy! Please Vienna give us your lights !!
My informations (Central Europe - maybe not valid for other markets) are:
BV7-32 Mk1 Type 9310-9320 and Mk2 Type 9321-9329 need FIRST being updated to "HD-Readyness"
(you'll need a HD-ready kit Type 4370 (part no. 1437000) + SW updates for the TV)
and THEN it is possible to install the DVB-HD T/C (HD-Terr. and HD-Cable) Module type 4674.
When SW does not fit there are a lot of things that can go wrong - nothing for DIY !!
Strongly recommend: a qualified B&O Service Center ...
The new DVB-HD T/C/S2 Module (HD-Terr.+ HD-Cable AND HD-SAT) CAN NOT be installed!
