Latest post 08-03-2010 4:39 AM by Mikemaxcel. 2 replies.
Page 1 of 1 (3 items)
  • 07-26-2010 5:19 AM
    Beocord 9000 no audio output
    Normal 0 <!-- /* Font Definitions */ @font-face {font-family:宋体; panose-1:2 1 6 0 3 1 1 1 1 1; mso-font-alt:SimSun; mso-font-charset:134; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 135135232 16 0 262145 0;} @font-face {font-family:"\@宋体"; panose-1:2 1 6 0 3 1 1 1 1 1; mso-font-charset:134; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 135135232 16 0 262145 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; text-align:justify; text-justify:inter-ideograph; mso-pagination:none; font-size:10.5pt; mso-bidi-font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:宋体; mso-font-kerning:1.0pt; mso-ansi-language:EN-US; mso-fareast-language:ZH-CN;} p {margin-right:0cm; mso-margin-top-alt:auto; mso-margin-bottom-alt:auto; margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:宋体; mso-bidi-font-family:"Times New Roman";} span.shorttext {mso-style-name:short_text;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} -->
    Normal 0 <!-- /* Font Definitions */ @font-face {font-family:宋体; panose-1:2 1 6 0 3 1 1 1 1 1; mso-font-alt:SimSun; mso-font-charset:134; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 135135232 16 0 262145 0;} @font-face {font-family:"\@宋体"; panose-1:2 1 6 0 3 1 1 1 1 1; mso-font-charset:134; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 135135232 16 0 262145 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; text-align:justify; text-justify:inter-ideograph; mso-pagination:none; font-size:10.5pt; mso-bidi-font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:宋体; mso-font-kerning:1.0pt; mso-ansi-language:EN-US; mso-fareast-language:ZH-CN;} p {margin-right:0cm; mso-margin-top-alt:auto; mso-margin-bottom-alt:auto; margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:宋体; mso-bidi-font-family:"Times New Roman";} span.shorttext {mso-style-name:shorttext;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} -->
    Normal 0
    The problem is caused by a faulty 7915(the measured voltage is -21V instead of -15V) and after replacing the
    regulator, a dead 9000 comes to live but the output audio signals accompany with unexpected loud annoying cracking distortion sound properly a symptom of burnt fets(Tr102 and Tr202) as the outputs are taken from R156 and R256.
    The burnt PF5103 fets are difficult to get.
    And  now I needed to tackle the problems of audio dB level display.It seems that the level display is in working order but with normal audio signal input ,the display hardly shown above -20dB! When cracking distortion sound get in,the level meter would shoot to full scale to +5dB.
    And you can`t find any information given in regarding to the calibration of audio display meter.
    Please help!
  • 08-03-2010 1:18 AM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Re: Beocord 9000 no audio output
    Hi there,
    Your post has a problem, it is barely readable!
    Could you please correct it?
    Thank you,
    Jacques
    Jacques
  • 08-03-2010 4:39 AM In reply to
    I Have tried several times without success!The message just repeated itself and getting longer and longer...!?
    Here is the original message posted:
    the regulator, a dead 9000 comes to live but the output signals accompany with unexpected load annoying
    cracking sound properly a symptom of burnt fets(Tr102 and Tr202) as the output are taken from R156 and R246.
    And now I needed to tackle the problems of audio dB level display.It seems the level display is in working order but with normal
    audio signal input (0dB level),the display hardly shown above -20dB! When cracking distortion get in the level meter would shoot
