Hi All
I am back with yet another problem.
I bought a new 7-40 earlier this year which was replaced within 2 months because of a fault with the screen. It also had an early SW version (7.05) causing the fans to race. By the way, my local dealer had no idea how to fix this problem until I passed on your forum replies confirming a known problem fixed by a later SW release (8.02). Thank you to everyone who helped me diagnose that problem.
Anyway, I regret to say that the replacement set has now developed the same screen problem. I dont really know how to describe it but what happens is periodically the colours go and you end up with fuzzy green images. Remember the film Predator? Well, the alien had the same view of humans when it was using its heat sensor! (sorry, for the bad analogy)
The problem comes and goes and is not consistent. It is also definitely the TV, not the broadcast as it happens when you watch a DVD.
Anybody else had this problem? clearly its a fault and I am going to get it replaced but I am starting to question B&O's quality and their quality control process (or lack of)
I am also going to write to B&O HQ at some point and ask them what is going on. My experience of local dealers is they are
technically poor and slow to react which is doing B&O's image in the UK no favours.
Thanks in advance for any replies.
Paul
