According to the specs it does.
| DESIGNER |
David Lewis |
| DIMENSIONS (W x H x D)/WEIGHT |
108.0 x 68.0 x 18.0 cm + stand/45 kg |
| COLOUR(S) |
Cabinet/frame: / / / / / / / Cabinet/Frame: Black/black, black/blue, black/dark grey, black/red, black/silver, black/golden, white/silver |
| CONTRAST SCREEN |
Contrast screen with anti-reflection coating on both sides |
| MAINS VOLTAGE RANGE |
200-240 V +10/-15%, 50-60 Hz |
| THEFT PROTECTION FEATURE |
Pincode |
| PICTURE FORMATS |
Format 1: 16:9 Panorama - 15:9 Panorama - 4:3 Format 2: Letterbox + Soft Scroll Format 3: 16:9 Automatic format optimisation via ""Black Bar Detection"" 16:9 detection on all Scart connectors Support of WSS (Wide Screen Signalling pulses) from broadcaster |
| HDMI INPUT FORMAT |
480p,576p, 600p, 768p, 576i, 480i, 720p, 1080i, 1080p |
| VGA INPUT FORMAT |
60 Hz 640 × 480, 848 × 480, 1024 × 576, 800 × 600, 1024 × 768, 1366 × 768 and 1280 × 720 |
| DIGITAL SURROUND SOUND MODULE |
Standard built-in |
| SOUND INPUT FORMATS |
PCM, multichannel PCM Dolby Digital, Dolby Digital EX, DTS, DTS ES. |
| DIGITAL SOUND DRCODING CAPABILITES |
Dolby Digital 5.1/EX 7.1, Dolby Pro Logic llx. DTS 5.1/ES 6.1/Neo:6 |
| SCREEN TYPE |
40" 16:9 TFT LCD, glare surface |
| BACKLIGHT TYPE |
Cold Cathode Fluorescent Lamp (CCFL) |
| RESOLUTION |
1920 x 1080 (Full HD) |
| REFRESH RATE |
200 Hz/240 Hz |
| LUMINANCE OF WHITE (CENTRE OF SCREEN) |
Typical: 500 cd/m2 |
| CONTRAST RATIO (CENTRE OF SCREEN) |
Typical 4000:1 |
| RESPONSE TIME (GREY TO GREY) |
Typical 6 msec. |
| VIEWING ANGLE |
+/-89 degrees both vertically and horizontally |
| PICTURE OPTIMISATION |
VisionClear |
| ROOM ADAPTATION |
Automatic Picture Control |
| CONTRAST ENHANCEMENT |
Global backlight dimming |
| MOTION PICTURE IMPROVEMENT |
Adaptive film judder compensation |
| VIDEO TYPE / FORMAT |
Analogue: B/G/L/L/I/D/K PAL, SECAM (According to type and setup), NTSC on AV. |
| FREQUENCY RANGE |
45 - 860 MHz: VHF, S-band, Hyper-band, UHF 99 programmes, auto tune, programme move and automatic naming |
| ANALOGUE STEREO DECODING CAPABILITIES |
A2 + Nicam Stereo |
| AERIAL INPUT CONNECTION(S) |
TV: 1 x IEC-con female |
| DIGITAL TUNER T/C |
Optional |
DVB-HD module, DVB T/C, MPEG2/4, HD reception, EPG, Common Interface for Conditional Access and embedded CONAX (card pairing not supported) required for (de-)scrambling pay TV |
| AUDIO TYPE / FORMAT |
MPEG1, 2-channel audio decoder, layer 1& 2 MPEG2, 2-channel audio decoder, layer 2 AAC, AAC+ AC3 decoding and down mix |
| LOUDSPEAKER |
External (recommended: BeoLab 7-4 for centre or BeoLab 7-2 for stereo. Ordered separately) |
| IR CONTROL OUTPUTS (PUC) |
6 x mini-jack |
| ANALOGUE VIDEO CONNECTIONS |
AV 1 to AV6 (AV4 used for integrated Blu-ray) |
| AV1 |
Video in/out + SPDIF + audio L/R in/out + PUC |
| AV2 |
YPbPr + SPDIF + Video in/out + audio L/R in/out + PUC |
| AV3 |
YPbPr + SPDIF + Video in + audio L/R in + PUC |
| AV4 |
For built-in disc player |
| AV5 |
VGA + Video in + SPDIF+ Audio L/R + PUC |
| AV6 |
S-video + Video in + SPDIF + audio L/R in + PUC |
| OUTPUT (RECORD OUT) |
2 x CVBS, 2 x L/R |
| PC INPUT |
VGA / HDMI |
| DIGITAL VIDEO CONNECTIONS |
4* x HDMI (*one used for Blu-ray player + one used for DVB-HD) Free configurable with AV1 to AV6 |
| DIGITAL SOUND CONNECTIONS |
5 x RCA phono, one dedicated for each AV connection |
| LOUDSPEAKER OUTPUTS |
7 x Power Link |
| STEREO HEADPHONES |
1 x mini-jack |
| MOTORISED STAND CONNECTION |
5 pin DIN connector |
| BEOLINK |
Master Link |
| VIDEO DISTRIBUTION |
BeoLink video distribution (system modulator output to link room) via RF |
| AUDIO DISTRIBUTION |
Stereo audio distribution via Master Link |
| PERIPHERAL UNIT CONTROLLER |
Integrated Peripheral Unit/Set-top Box Controller: Controlling 6 units |
| SPLIT SCREEN |
Picture and picture Picture and teletext |
| TELETEXT |
Teletext level 2.5 approx. 2048 pages 9 memory pages per programme |
| SPEAKER MODES |
Speaker modes 1-5: Mode 1: Stereo centre speakers (subwoofer muted) Mode 2: Stereo in L/R speakers (subwoofer is active) Mode 3: Dolby 3 stereo Mode 4: Dual stereo, stereo in L/R front and rear speakers (subwoofer is active) Mode 5: Dolby digital, Dolby Pro-logic, DTS, Dolby 7.1 |
| MENU LANGUAGES |
English, Danish, Dutch, Spanish, Italian, German, French, Swedish |
| HOME CINEMA |
Standard built-in |
| FRONT PROJECTOR CONNECTION |
1 x DVI-D |
| HOME CINEMA CONTROL CONNECTION |
2 x IR outputs for control of external functions1 x D-sub 9 male output for control of external functions |
| EXTERNAL IR RECEIVER |
1x mini-jack (without automatic picture control) |
| BLU-RAY DISC PLAYER |
Optional |
| BD-LIVE |
Yes, BD-Live profile 2.0 |
| BD-JAVA |
Yes |
| INTERNAL MEMORY |
2 GB |
| SUPPORTED DISC FORMATS (PLAY BACK) |
BD-ROM, BD-R/RE, DVD-ROM, Audio CD, CD-R/RW (CD-DA only), DVD-R/RW |
| SUPPORTED AUDIO DECODING FORMATS (FROM DISC) |
Dolby Digital 5.1/EX 6.1/EX 7.1/Dolby Digital Plus 7.1/True HD 7.1. DTS 5.1/ES 6.1 MPEG audio L1, L2 LPCM, 7.1ch multi-channel PCM |
| DVD/BD REGION |
According to type |
| ETHERNET |
1 x RJ45 (BD-Live and firmware update) |
| PLACEMENT OPTIONS |
Motorised stand low (BeoLab 7-2) Motorised floor stand high vertical (BeoLab 7-4) Motorised floor stand high horizontal (BeoLab 7-2) Motorised wall bracket Fixed wall bracket for TV - close (BeoLab 7-2/BeoLab 7-4) STB Cover large STB Cover small |
| REMOTE CONTROL |
Beo5 (recommended) or Beo4 - Optional |
