Latest post 07-31-2010 11:06 PM by elephant. 3 replies.
Page 1 of 1 (4 items)
  • 07-30-2010 7:41 PM
    BeoVision 8 POWER SWITCH
    Hi guys.
    Please, can someone answer this question?
    Does the BeoVision 8 have a master switch? To turn it completely on/off (not with remote)???
  • 07-31-2010 1:03 AM In reply to
    Re: BeoVision 8 POWER SWITCH
    I have never found one.
    The manual's pictures don't show one.
    And the wording of the instructions implies there is not one:
    • "When connections are complete and cables have been secured as described on the previous page, switch on the mains. A tiny, red light appears. The system is in standby mode and ready to be used."
    • "Your television was designed to be left on in standby mode when not in use."
    • "The television can only be switched off completely, if you disconnect it from the mains."
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 07-31-2010 7:09 AM In reply to
    there is none.
    would also not make sense in a Link setup, when speakers are connected to BV8.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 07-31-2010 11:06 PM In reply to
    Heribert:
    Link also works with just internal speaker as well
    But you are correct, the link design mandates that all master units must be "online" at all times to respond to commands to use their sources
    And when the BV8 it sourcing a link room its own screen does not come on ...
