Hello BeoWorlders,
I tested the VGA projector output on my BV7-32 mark IV, and although the TV & DVD sources are displayed correctly while pressing "FORMAT 0", the HD input sources (PC via DVI, and VMEM -TVIX- via component) do not display anything, instead I get a warning saying something like "protected content/cannout output").
Is there a trick in the setup menu that I have to do to make this work, or will it never work at all?
Reunion Island is greeting you!
