stotty1111:
How would I tell the mk?
its a type 9344, serial no 1828770,and no 21277893
Also do you have a rough figure for the upgrade(euros)
BeoVision 7 - 32 MK III = type # 9331-9339, 9341-9350, 9399
BeoVision 7 - 32 MK IV = type # 9171-9180
BeoVision 7 - 32 MK V = type # 9181-9190
# 21277893 is a Mk3 and you'll need retrofit-kit B&O-order/item # 1445000
I could not find # 1828770 - maybe transposed digits ?
EUR 650,- surcharge including 20% VAT for 7-32MK5 with HD-TERR/CABLE/SAT ex factory
Retrofit should be approx. the same, plus labour and SW-update
