Latest post 07-23-2010 6:28 AM by Mikemaxcel. 1 replies.
Page 1 of 1 (2 items)
  • 07-16-2010 3:25 PM
    My newly acquired Beocord-9000, no audio output
    My newly acquired Beocord 9000 arrived this afternoon from Holland.
    The deck has been serviced once by B&O 10 years ago
    and have been kept unused for the last five years according to
    information given by the  seller.
    As I powered-up, the mechanism responsed smoothly  to all the function-buttons
    and in play-mode,with  signals shown in the leds meter confirming the head picked-up signals from the tape,
    I  was surprising to hear no audio sound from the headphone.
    In calibration-mode, mine has the `REC-OPEN` flashes instead of `REC-CAL `.
    Any suggestion given to aid me to solve and repair the faults that this deck might shine once again as it should.
  • 07-23-2010 6:28 AM In reply to
    Re: My newly acquired Beocord-9000, no audio output
    The problem is caused by a faulty 7915(the measured voltage is -21V instead of -15V) and after replaced the
    regulator, a dead 9000 comes to live but the output audio signals accompany with unexpected loud annoying cracking distortion sound
    properly a symptom of burn fets(Tr102 and Tr202) as the outputs are taken from R156 and R256.
    The burnt PF5103 fets are difficult to get, any suggestion for a substitution?
