When you are signed in and on the forum scroll to the top of the page.
Select/click on Edit Your Profile
You should now see a web form where there are 3 tabs along the top
[Profile Options] [Site Options] [Sign-in information]
You want [Profile Options] to be the one that is highlighted in bold test
First make sure the radio button "Enable Avatar (*) Yes ( ) No" is selected
Then check if no avatar picture exists on the page under Avatar ... you need to load one
Click Upload Avatar (Choose File) button
A MENU WILL POP UP FOR YOU TO SELECT YOUR IMAGE FILE FROM YOUR COMPUTER
Once you select a file and return to the Beoworld webpage you need to then click the (Update) button
A page refresh happens but your Avatar picture remains unchanged
Then scroll to the bottom of the webpage and click the (Save) button
Another page refresh happens and then the Avatar picture is replaced
And voila you are there
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
