Latest post 07-17-2010 4:16 PM by Beobuddy. 6 replies.
Page 1 of 1 (7 items)
  • 06-06-2010 8:42 AM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Two STB's. Y-adaptor 6174171 and a IR-blaster 8330352. Or?
    If I fitted a 2nd STB to my BeoVision would one of these work link instead of the B&O official parts Y-adaptor 6174171 and a IR-blaster 8330352?
  • 06-06-2010 11:21 AM In reply to
    Re: Two STB's. Y-adaptor 6174171 and a IR-blaster 8330352. Or?
    Hi, no it wouldn't - this is a single cable with 2 x IR emitters, whereas the Y-adaptor above splits the individual IR signals and assigns them to the appropriate channel (STB/DTV & V.AUX/STB).
    Would be great if it would but it won't.
  • 07-16-2010 7:28 AM In reply to
    • kallasr
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    (r),
    did you try this?
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 07-16-2010 11:56 AM In reply to
    • UK
    • Posts 970
    No. No - thumbs down
  • 07-17-2010 10:49 AM In reply to
    The above showed adapter/ir- isn't a splitter. As you can see it has just a 3,5 "mono jacket.
    B&O uses a splitter a 3,5" stereo jacket where the middle section is the V-Aux and the top section is the DTV/Sat. Both uses the bottom section as a common ground.
    So, if you can solder a bit, you can make easily one yourself.
  • 07-17-2010 1:35 PM In reply to
    • kallasr
    • Posts 1,077
    Unfortunately no soldering skills here...
    Mono jacket means both signals are sent to both boxes, but the box not understanding the signals won't react. So that would not be an issue, right? But I probably miss something here...
    Could I use a mono ir blaster (one ir at the end, available from lots of companies) to control one STB? This should be a very common.
    Then two of those and the y-cable/splitter? Or grounding issues?
    Sorry to bother...
    Ralf
  • 07-17-2010 4:16 PM In reply to
    kallasr:
    Correct.
    kallasr:
    This is the normal way, just 2 mono leads and the y-splitter.
