Can`t have worked before. When you are listening to RADIO in the mainroom, Masterlink is occupied by the RADIO signal. So no way to get a different signal onto the Masterlink. When you are listening to the Mac in the mainroom, Masterlink is free to send audio to linkrooms, because the Mac is connected via analog stereo or spdif to your BS3. But you can listen to a video source in video linkrooms, because in this case audio is distributed via antenna cable to (video) linkrooms. Hope this helps.
Stefan
