Latest post 07-10-2010 11:19 AM by beojeff. 3 replies.
Page 1 of 1 (4 items)
  • 10-26-2009 3:37 PM
    Samsung Blu-ray DVD with BeoSystem 1/BV4
    Hello all,
    I recently upgraded my DVD to Blu-ray (Samsung BD-P3600; thank you Michael for the recommendation) but I am having some trouble with the connections. I searched the forums and tried everything but I am still getting no video (black screen) and audio seems to work fine.
    I have a zektor switch with the BeoSystem 1 (BeoVision 4) and have my DVR, Blu-Ray, iMac and Wii hooked up through component cables. All other external devices work properly but the DVD will not show video through component.
    I set the Samsung BD-P3600 to output video at 480p and it didn't work and I also tried 1080i to no avail. When I had it set up through analog video cable it worked fine but quality was low. I also have the DVD set to Samsung BD-P1000 in the external devices under the BeoSystem 1 so I assume it should look for component first. Do I have to do a hard reset (unplug mains for 30 seconds) when hooking up new devices to the BeoSystem 1?
    Any ideas?
    Thanks,
    Diggs
  • 10-27-2009 9:55 AM In reply to
    Re: Samsung Blu-ray DVD with BeoSystem 1/BV4
    Update:
    I still have it set at 1080i and only component cables going from the blu-ray dvd to the beosystem 1 (for video). I changed from STB to DVD on the Beo5 and the Samsung (no disc was in) start screen came up and it was very blurry and had lots of lines going through it etc. When I hit the Menu button on the Samsung DVD remote the BeoVision 4 actually shut off. No other equipment shut off and actually all sound worked fine. I had to hard reset the Beosystem 1 to get the TV to work properly again. Am I correct to assume that the output from the DVD player is still incorrect? Should I try 480P again?
    Thank you,
    Diggs
  • 10-27-2009 12:46 PM In reply to
    Turns out that new Samung Blu Ray DVD Players DO NOT work with the BeoSystem 1!!!!! Now I have to look for a new Blu Ray that is compatible with the BeoSystem 1 and can stream Netflix/Pandora. Any ideas or recommendations????
    Thanks!!!
  • 07-10-2010 11:19 AM In reply to
    I, too, recently purchased a newer-model Samsung BD player and encountered this same issue. I'm wondering if others have been encountering this problem and if they've gotten any feedback from B&O tech support. I can't imagine what could be different about the Samsung component connection that makes it incompatible with the BeoSystem 1 when other makes of blu-ray players work fine.
