Latest post 07-10-2010 5:48 AM by Vienna. 3 replies.
Page 1 of 1 (4 items)
  • 07-09-2010 8:07 PM
    BL4000 direction at a desk
    Hi, I'm going to set up my BL4000s at my desk and only get one shot to set them up so I'm looking for people who have done this. Basically, my question is: should I face the speaker grilles in or out? As in, should the speakers be firing right at me or should they be firing into the room in general? It doesn't have to entertain a whole room since it's a small room and usually only one person at a time will be in there.
  • 07-10-2010 1:28 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: BL4000 direction at a desk
    If the listening position is fixed then i would face them inwards. Why do you say you only have one chance, you can experiment even if they are wall mounted because they can be easily attached either way with the wall brackets...
  • 07-10-2010 4:53 AM In reply to
    The one on the right won't be easily reachable, physically. Not without needing Tom Cruise's Mission Impossible harness anyway.
  • 07-10-2010 5:48 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Dave:
    Maybe you should check the the angle in a test set-up.
    When you remove the covers you'll see the precise direction of your speakers.
    The axes of both speakers should meet slightly behind your preferred listening position.
