Hi
Has anybody come across this scenario before?
BeoVision7 40" in main room with Sky HD box attached and controlled via PUC.
BeoVision6 connected via Masterlink in link room.
All operation is fine in main room and link room EXCEPT no access to red button functions in link room if main TV is in stand by.
If the BeoVision7 40" is switched on ALL sky operation is fine and the same in the link room IF the Bvis7 40 is on. If the Bvis7 40 is in stand by, the BeoVision6 in the link room will switch on the Sky box and control it, however it cannot use the red interactive function if the BeoVision7 40 is off.
Bang & Olufsen say it is a Sky problem.
Any thoughts/comments?
Opman
