Latest post 07-09-2010 11:02 AM by linder. 3 replies.
Page 1 of 1 (4 items)
  • 07-09-2010 4:31 AM
    Is anyone actually using a BV10 with a BL11?
    Is anyone on the forum actually using a Beovision 10 with a Beolab 11 to add to the missing bass frequencies? Does it provide an adequate sound set-up for the BV10 in an average sized room?
    I can see several suggestions on the forum that this might be a good combination. I am thinking of this combination for a bedroom where there will be no need for high sound volumes due to the proximity of neighbours and the fact that most use will be late in the evening. So, to my mind, that rules out options involving high output surround sound speaker systems. The BV10/BL11 would be a replacement for a very adequate Avant 32: adequate, that is, in every respect except for its physical bulk!
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 07-09-2010 7:07 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Is anyone actually using a BV10 with a BL11?
    vikinger:
    Yes, 30m² / BV10-40 / BLb11 / no further speakers connected
    ... soundwise emphatically YES - maybe you should consider a pair of e.g. BLb 4 to get a wider soundstage ...
  • 07-09-2010 10:47 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Hi Graham
    I have sent you an email
    Opman
  • 07-09-2010 11:02 AM In reply to
    vikinger:
    Graham
    I have this combination on order but don't have a delivery date yet.  I have heard and seen a demo of this combination and really liked it.  The BV10/BL11 will be in my living room at first but will ultimately be in a bedroom.
    Bill
    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
