Hello,
are any owners of BeoVision 6 TV's having problems such as:
Loud anoying hiss on the sound, (it is only when sound is muted that the hiss stop).
The clock does not work correctly, and so gets the program guide wrong by an hour.
The channel information and program guide do not work properly, not showing all channels program data.
The STB controller does not correctly operate my Panasonic DVD that is connected by a HDMI lead, for example it does not turn the DVD off and the next time the TV is turned on, the DVD does turn off. I then need to press yellow on the Beo4 for example to get it to turn the DVD back on again. It used to work when connected with SCART but as it has HDMI it should work with that too.
Other models using the same DVB module may also be having problems. Any feedback would be good so I can pass it to my dealer to help get these problems resolved.
Steve
