Well, the MK V is a 200 hz panel, so it should help eliminate panning issues. However, as Moxxey, i do not have a panning problem with my Mk IV, but then again it also updates twice as fast as the Mk III. If you watch a lot of sports and fast moving tv or movies, i would definitely go for the new Mk V..cant wait untill i get mine..
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
