Hello folks,
I finished the recap of my BM8000. Sound has improved greatly! It makes my M100's sing
However, there are two things left I'd like to do something about:
- After the recap, the tuner automatically and immediately mutes any radio station I select, unless tuning is in 'manual' mode, then it sounds better than before. I think I should adjust the sensitivity of the muting circuit, but I can't find how in the service manual. Where to look?
- The heatsink beneath the display is getting pretty warm(was also before the recap). It's probably normal, but maybe some setting can be changed to make the transistors there (voltage regulators?) run a bit more cool?
Now better start looking out for a BG8002!
