Latest post 06-06-2010 3:30 PM by moxxey. 9 replies.
Page 1 of 1 (10 items)
  • 06-04-2010 12:11 PM
    Beovision 10-40
    Am thinking of adding the above TV to myBeoSound 3200+BeoLab 8000+BeoLab  2.  I also have a Virgin HD + DVD player to attach at the back.
    Any feedback on Beovision 10-40 or is BeoVision 7-40 a better buy?  Thanks.
    Filed under:
  • 06-04-2010 5:33 PM In reply to
    • Jez
    • Top 500 Contributor
    • Joined on 06-13-2007
    • Posts 150
    Re: Beovision 10-40
    I have both and much prefer BV10. If you already have a DVD player there isn't a big advantage with BV7-40 apart from a superior sound. Maybe get your local store to demo the sound of both with BL8000 + BL2 and see how the centre sound matches up.
  • 06-05-2010 8:39 AM In reply to
    Re: Beovision 10-40
    Thanks for that.
  • 06-05-2010 1:54 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: Beovision 10-40
    Jez:
    ...there isn't a big advantage with BV7-40 apart from a superior sound.
    That's a pretty big advantage. 50% of the TV experience! What other advantages do you require? :)
  • 06-05-2010 4:35 PM In reply to
    • Jez
    • Posts 150
    Re: Beovision 10-40
    Well he/she may be satisfied with the sound of the BV10, especially after BL8000's and BL2 are connected. That's why I recommended a test drive in store.
    I believe I described it as "superior" and recommended a test drive and see/listen how it "matches" up.
    I for one am extremely satisfied with the sound of the BV10 with BL3's and BL2. Although this is in a bedroom so it is a little overkill.
    Just one opinion and recommendation.
  • 06-06-2010 6:47 AM In reply to
    Re: Beovision 10-40
    I'm over the moon with my BV10-40
    I have a BC2, Sky HD, Apple TV and a Wii connected to it...
    On the Audio front, I have BL8000s connected and want to demo a BL11, but I'm more than happy with the current sound/ picture quality!
    I never really warmed to the design on BV7 and find it rather overpriced in my opinion.
  • 06-06-2010 9:56 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Re: Beovision 10-40
    gk31ax:
    Yes, the BV10-40 is much better value than a BV7-40. Perhaps the BV10-40 + BL11 combo might be equal to that of a BL7.2.
  • 06-06-2010 11:53 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: Beovision 10-40
    moxxey:
    Really? 7-40 includes DVD drive (which is gorgeous) and beosystem 3 inside, how is it over priced compared to a BV10?
  • 06-06-2010 3:26 PM In reply to
    Re: Beovision 10-40
    Thanks for that - I plan to connect the BL9000, subwoofer BL2, BS3200 - so the sound should be fine.
    I also have a Virgin HD, Blue ray DVD and Wii console - hope there are enough connections to have all these.
    I guess with Apple TV - once can see all the stored pics/ movies also?
  • 06-06-2010 3:30 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Re: Beovision 10-40
    Dave:
    The DVD drive that doesn't support DTS-HD? The Beosystem 3 might be great if you want to control a projector and other devices, but the picture quality isn't necessarily any better. Indeed the BV10-46 has a better picture, without BS3.
    If you want to pay over £10,000 for a BV7-40, feel free :) I think the BV10-40 represents good value for a B&O TV. The BV10-46, less so.
