Latest post 06-06-2010 4:29 PM by Craig. 3 replies.
Page 1 of 1 (4 items)
  • 06-06-2010 1:34 AM
    mcl passive x-tra speakers transceiver
    I am lucky enough to have inherited a B & O BeoSystem 4500 (alas, without the turntable).  I also have the full MCL passive x-tra speakers kit, and two extra passive speakers.  I began set up over the weekend, and when I tested the connections (from the relay box a blue cable is attached which ends in six bare wires, which I attached to a short cable with pin connectors to the BeoMaster), I was able to control the extra speakers with the transceiver.  A red light came on and off when I pressed it.
    Well then I fed the blue cable through a hole in the wall to get the speakers in the next room and set up the relay box near the speakers. I reconnected the whole thing, and now the transceiver doesn't work.  I CAN get the passive speakers to work when I turn on the BeoMaster in the next room - then both sets of speakers turn on.
    I also set up the Beolink 1000, and it works with the BeoMaster, but not with the transceiver.
    Only one thing happened - I dropped the relay box while setting it up (on carpeting).  Help!
  • 06-06-2010 4:16 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: mcl passive x-tra speakers transceiver
    Hello, and welcome to Beoworld. Did you remove the 2 connections from the Beomaster, to feed the wire through the wall? If so make sure they are the correct way round. This is quite a common problem when connecting MCL systems.
    CraigSmile
  • 06-06-2010 10:09 AM In reply to
    Horray!  You were right!  Apparently the extra speakers have to be plugged into the bottom plugs on the BeoMaster.  That did it.
    Thanks soo much.
  • 06-06-2010 4:29 PM In reply to
    • Craig
    • Posts 4,855
    michelesmith55:
    Thanks soo much.
    Forgot to mention that too, I was refering to left and right. Glad to hear you got it working in the end though.Yes -  thumbs up
    CraigSmile
