NEW FEATURES:
MOTS
  ·  Exclude from MOTS
  ·  Exclude from previous album
  ·  Disable MOTS
  ·  MOTS status + progress bar
  ·  MOTS logo
  ·  MOTS button on Beo4 (1710)
System functionality
  ·  BeoSound 5 placement in link rooms
  ·  BeoSound 5 in option 1.1 and 2.2
  ·  BeoVision 8-40, 10-40 and 10-46 compatibility
  ·  Master Link Gateway compatibility
  ·  Support for older televisions / IR compatibility
  ·  Play Timer (on/off)
  ·  More than one BeoSound 5/BeoMaster 5 in a setup
Miscellaneous
  ·  OS updated to version 6.01
  ·  Performance at start-up improved
  ·  Password in user service menu
  ·  Show share & user name in NETWORK INFO
  ·  New setting for N.Radio buffer length
  ·  New setting for adjustable start time in N.Music
  ·  ABOUT box introduced
  ·  Driver for Bang & Olufsen approved wireless adaptor GN-WB31N is incorporated
  ·  Flash Player 10 support
  ·  Status on Bonjour
  ·  Support for Russian (Cyrillic) character set
  ·  Improved internal logging for debugging purposes – for instance logging of received and
     issued Master-link commands
