Hi all,
Yesterday I received my audio link cable of sufficient length. So I finally connected my Beomaster 5500 with my Beovision LX6000.
Everything seems to be connected OK. The BM uses TAPE2 / AUX and de BV the audio link socket (both 7 PIN, and fully wired cable).
Now I can play my radio, cd or phono over the loudspeakers of my TV. And the sound of my TV over the audio system.
Just 1 thing / problem
. When I play a video or DVD I still get the audio from the last selected TV channel over my amplifier (the picture and sound on the TV is from the VCR). Is there a solution for this?
By the way I use both BL1000 and Beo4.
i.e. for radio over tv set: AV -> Radio
tv over BM AV -> SAT (AV -> TV gives no reaction, nor does AV -> V.TAPE).
hmmm.. "Problem solved"
Solution -> RTFM (Read The F. Manual)
I just read through the MCL manual. [LINK] ilo [AV].
