Hi Martin and others,
Thanks for your comments - saved me making a mistake and getting it in the neck from my wife.
I do not have a circuit diagram for the BG 8000 but had heard it was micro controlled and not a synchronous motor.
I am watching a US BG 8000 and it currently is a good price. Needs a tachodisc etc. What sort of cost is a power/transformer module (240V 50Hz) and is this an option?
Another question, how would you rate a BG 3000 to a Beocenter 2002 LP player soundwise? I have limited experience with other LP players (Beocenters 2002, 4600 and 5000). Is it comparable, slightly better or much better?
Finally, with the MMCx range was there point that the rest of the player stopped you getting the real benefits of the better MMCx? Ie putting a MMC1 in place of a MMC4 onto a BG 3000 makes little difference to the sound whereas changing from a MMC1 to a MMC4 on a BG 8000 would make a marked difference.
Thanks again and sorry if these are silly questions - I believe if your do not ask you do not learn.
Cheers
Richard
