I've heard conflicting things... does the eye for the Active Link work on Beoport?
Thanks.
No, the connection is different.
The Beolink Active eye has buttons, so it needs extra wires.
p.
Mac, iPad & iPhone Apps: Beoworld, LinkPlayer, LinkRemote, Story Mouse, The Emperor's New Clothes
Should work with IR, ground and 5V wired with a 3.5 mm stereo plug - no volume control....
http://www.beoworld.org/beotech/ir_eye_wiring.htm
Stefan
It works, I have the full IR eye with the controls, and with a normal wiring as Stefan says, it works great.
Reunion Island is greeting you!
I use the IR eye from the old VX 5000 external IR.No change in wiring, plugs straight into Beoport. Found it on eBay for £11.
Poor me, never win owt!
