Hi, I'm getting different answers to how well a BeoSound 2300 and BeoLink Converter will work as ML Driver. According to the documentation of the BeoLink converter it should be possible to use for "distribution to a Master Link based BeoLink system".
Does this mean that it will have ML functionallity as for an example a Overture (i know that i will not sent Light + Control commands)?
Can anybody explain what the ML limitations will be in a setup as above?
The main question is; will I be able to connect a Master Link Gateway to it and start musik in my bathroom on my BeoLab 3500 from the Iphone app?
Thanks/Lars
