Hi there,
I have a very odd problem with my beosound 9000.
I'm using it with a Beo 4 remote as most of you I think and one day the IR port stoped working I think.
The only thing I did , was moving the speakers arround and then reconect them . When I tried to access the beosund with hte remote - nothing happened.
I thought at first that batteries were dead, but nothing happens with the new ones also. I borrowed a Beo 4 from a friend and it doesn't work also. My remote is working ok on his system.
Can anyone tell me what to do ? Did this happen to any of you ?
Is it possible that the usint to gather dust on the IR port in time and then stop reading my remote ?
Many thanks to all of you.
Stefan
