Latest post 04-30-2008 11:35 AM by tournedos. 4 replies.
Page 1 of 1 (5 items)
  • 04-30-2008 7:36 AM
    Video Terminal (Mars bar) remote codes?
    I'm taking my MX2000 to the summer house and got a new (old) Humax STB to use with it. It has a programmable remote which is able to control the most basic functions of a lot of televisions (on/off, volume), so you can for the most part live without touching the remote of the TV.
    I'm sure there's no hope for it to able to use the later B&O 455 kHz remote standard, but is the Mars bar of MX2000 similar to something else that I could try? There's no mention of Nordmende in the code list, and the three different codes given for ITT didn't work either.
    On/off would not be a big problem, but the Humax doesn't have any kind of volume control in itself.
    -mika
  • 04-30-2008 7:52 AM In reply to
    Re: Video Terminal (Mars bar) remote codes?
    Could you not turn the problem around the other way and use a universal remote that does both?
    Neil
  • 04-30-2008 8:02 AM In reply to
    That would be a solution, but I'm afraid such a remote would cost me more than the MX and Humax put together Big Smile
    I could also get another STB with integrated volume control and use the Humax elsewhere. It has the advantage that the tuner is so sensitive that a 20 cm loose wire will do as an aerial...
    -mika
  • 04-30-2008 10:54 AM In reply to
    You could strap the two together using tape Stick out tongue
  • 04-30-2008 11:35 AM In reply to
    nobby:
    Reminds me of the "camera phone" I once built Laughing
    -mika
