Latest post 05-01-2010 4:10 PM by quader. 9 replies.
Page 1 of 1 (10 items)
  • 04-27-2010 11:15 AM
    • quader
    • Top 500 Contributor
    • Joined on 08-03-2007
    • West Yorkshire, UK
    • Posts 89
    • Gold Member
    Home automation & Projectors for BV 7
    Hi
    Could someone help on or direct me to get info on the above
  • 04-27-2010 3:54 PM In reply to
    Re: Home automation & Projectors for BV 7
    A Very Warm welcome to Beoworld and your first posting.
    Exactly what did you want to know about Home Automation and Projectors for the Beovision 7 ?
    Regards Keith....
  • 04-27-2010 5:44 PM In reply to
    I've often thought that a detailed FAQ or BeoTech page on this site regarding home automation would be very nice. I'm sure many BeoWorlders are interested in doing such an installation themselves.
  • 04-27-2010 6:19 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    I have a Optoma HD65 connected to my BV7MK3 and when i get time and funds i will prob but the lintronic 238 box to switch the projector on and off with the rs232 as the trigger.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 04-28-2010 12:25 PM In reply to
    • quader
    • Posts 89
    • Gold Member
    Thanks keith,
    I would like to know what i would need to control the lights,are these special lights or is it the controls that are important
    same for the blinds,
    As regards projectors - can any work with BV7 ?
  • 04-28-2010 12:26 PM In reply to
    • quader
    • Posts 89
    • Gold Member
    I agree
  • 04-29-2010 3:22 AM In reply to
    When it comes to projectors and home automation in general integrated with B&O products, this falls under the umbrella of Beoliving and only a few dealers are provided with the detailed technical information required for these customer opportunities. The B&O strategy is to focus on the bigger fully integrated projects and effectly manage them seperately. This is fine for the big ticket customers, but this does limit the customer who just wants to add a projector and some lighting control.
    With the introduction of the Beolink gateway and the Beo5 in particular helped customers who just wished to add a few third party products normally not purchased from B&O and I have compiled a list (not totally complete) of 3rd party products supported by B&O
    • 3BM Smart Light Switch
      Samsung Projectors
      Xbox360
      Apple Remote old model
      Apple Remote new model
      BtiCino Video Door entry Products
      Busch-Jaeger range of automation products
      Clipsal lighting control
      Daikin Airconditioning BRC4C152
      Faber Roller blinds
      Feller BeamIT
      Future Automation stands and brackets
      Helvar Digidim lighting system
      Herstal Light Control
      Hunter Douglas Shades
      Kessebohmer Screen Motion system
      Lava RC601 TV stand
      LG Airconditioning
      LK TOUCH 350 lighting
      Lutron Homeworks home Automation
      Lutron Maestro
      Lutron RadioRA
      Lutron Rania Dimmer
      Lutron Rania Dual Dimmer
      Lutron Sivoia QED shading solutions
      Merten 2010 Lighting
      Merten 2050 Lighting
      Salamander Big Fire Fireplace
      Sanyo Airconditioning RCS-8PS3E
      Sony_PS2 Slim
      Velux WLR 100 Window Blinds
      Velux_WUR 101 Window Blinds
    All the products above can be directly controlled using the Beo5 and many via the Beolink Gateway. When it comes to projectors Samsung remains B&O's main partner and there can be issues using some non supported projectors with the Beovision 7 as some members have discovered.
    Whilst I have stated what B&O supports, this does not need to restrict you choice, I suggest you first decided exactly what you want in terms of functionality and also how much you are prepared to spend.
    Regards Keith....
  • 04-29-2010 9:37 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Thanks for the list - i will do some research in the meantime
    what is the approx cost for
    1. controlling lights/blinds - are these sepecial lights for the Dimmer to work?
    2.projector/screen.
  • 04-29-2010 11:34 AM In reply to
    With regards to projectors, the only ones which B&O formally approve at present are the Samsung SP H700 and SIM2 HT300 PLUS which are shown in the connections menu on the Beovision 7
    In terms of controlling external 3rd party products from the Beovision 7-32 or 7-40 you can purchase a Cinema Control Module to control curtains, lighting and motorised projector screen etc. It has two control outputs which are used to control external equipment.
    In terms of cost, well clearly that depends on what you want, but most 3rd party products are the company's standard products and as such do not have to be purchased from B&O.
    All the 3rd party lighting systems are standard with Lutron being at the top end and what you will see shown in most B&O shops.
    Regards Keith....
  • 05-01-2010 4:10 PM In reply to
    • quader
    • Posts 89
    • Gold Member
    do i need Lutron Grafik eye with lutron rania dimmer, what is lintronic 238 box
