1st March February 2012
Latest post 04-27-2010 3:18 PM by Craig. 9 replies.
04-20-2010 10:09 AM
ajames
- Joined on 05-04-2007
- Posts 275
Hi there
I've cancelled my Sky+ Subcription and have been told that I won't be able to record on it anymore, so I've thought about getting a Humax PVR - I noticed that on the list of supported PVRs there is a Humax PVR 81something but the one I've seen is a 91omething in Tesco - has anyone bought one recently and can confirm if it will work with the Avant. If not I'll borrow one and test it before buying or does anyone know if there is a way of using the Sky+ box to record without a subscription?
Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
vikinger
- Joined on 04-16-2008
- Vestri Kirkjubyr, UK
- Posts 2,839
ajames:
Hi there
If you dig around on the Lintronic.dk website you can get a good idea about whether current models of Humax etc retain the same codes as earlier models shown on your Avant STB-C. (Pick the models you want to compare and then look at the codesets to look for matching numbers and button controls.)
I'm not aware of how you can use Sky+ recording without a subscription: I am running an HDR1 with Freeview.
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
ajames
- Posts 275
Thanks Graham - what type of Freeview box are using - I have a spare Sony one and wondered of HDR1 could control that?
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
ajames:
Just cancelled mine, and was told the same. Also you cannot watch what you have saved on there either. Might be worth seeing what the latest Avant STB list contains. Changing the SW chip is a fairly easy job. Managed to do mine in about 15 mins.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
vikinger
- Posts 2,839
ajames:
I'm using a Panasonic TU20/30 type Freeview boxes (one on Avant, one on BV5). I took a chance purchasing an HDR1 and found that it was in the STB list. If I'm not mistaken someone else has reported that the HDR1 PUC list can be updated easily by a B&O dealer (take the box in rather than call the dealer out. )
Graham
ajames
- Posts 275
I've e-mailed Humax as could only find one box on the Lintronic site. Failing that I'll test it at the weekend with a friends box - if it doesn't work I guess I'll upgrade the chip in the STB-C as the latest one seems to support it. The problem I've had in teh past with getting the upgrade is that the dealers want to install it and seem reluctant to just sell me the chip.
Craig
- Posts 4,855
ajames:
Where are you? Might know a dealer that can help. Some seem fine to order spare parts and others just do not want to know.
Craig
ajames
- Posts 275
Hi there, I'm based in London, so if you know of a london dealer that is happy to just provide the upgrade chip that would be great - I've changed one before and its relatively straightforward.
Regarding the sky subscription, i found a site that said a few people have had their cards carry on working but not for long. It's quite annoying as I paid around £300 for the box a few years ago and now find out that you have to have a sky subscription in place to be able to record. Will switch to a freeview or freesat box that is supported by the STB-C. There doesn't appear to be a hack as the recording part of it is completely controlled by the card and having a valid subscription in place.
Craig
- Posts 4,855
ajames:
Try B&O Watford, I have just moved. Spoke to them the other day as they are now my nearest dealer. They said there would not be a problem to order me any spare parts I require. All they said is if they order anything. It cannot be returned. Which is fair enough I suppose.
Craig
Page 1 of 1 (10 items)
