Latest post 07-03-2007 1:37 AM by Hank. 3 replies.
Page 1 of 1 (4 items)
  • 07-02-2007 10:59 AM
    • Hank
    • Not Ranked
    • Joined on 04-17-2007
    • Posts 25
    Help with changing the Bottom and Top plate BEOLAB 4000!
    I just bought a pair of Beolab 4000, they were realy bad condition in the top and bottom plate.
    So I just recieved my new 4 pc of aluminium from B&O store.
    Now I need help with info to remove the old ones, the new seems to be glued togeter with main unit.
    Someone that have done this before?
    Best Regards Hank
  • 07-02-2007 7:00 PM In reply to
    Re: Help with changing the Bottom and Top plate BEOLAB 4000!
    They are put on with double glue tape, stick a screw driver under the plate and lift up (they cannot be reused Wink)
  • 07-02-2007 10:25 PM In reply to
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    Hehe.. What material is it under the aluminiumplates?  Sheep plastic cabinet or?
    BL8000 MkII Black
  • 07-03-2007 1:37 AM In reply to
    • Hank
    • Not Ranked
    • Posts 25
    Hi
    Under the plate is it some kind of hard plastic.
    You were right they are not going to be reused now! The old ones looks like an opened can. I were glued very hard!!
     But now they looked like new.
    Best Regards Hank
