Is it possible to use two 1611 converters in the same setup? I propose to use BV7mk2>1611>BC9500>MCL Xtra TV>1611>Avant 32 DVD.
The PCG does not list the Avant as a possible link TV when using the MCL system.
David
Probably not!
the more " obvious" connections would be:
BV7>ml>Avant
>ml>1611>BC9500
david707: Is it possible to use two 1611 converters in the same setup? I propose to use BV7mk2>1611>BC9500>MCL Xtra TV>1611>Avant 32 DVD. The PCG does not list the Avant as a possible link TV when using the MCL system. David
Interesting. I assume you want to integrate local audio sources in the link room..(?) I dont know why it should not work. I had a mixed ML / MCL system with a 1610 converter and a BL video years ago.
Stefan
I can integrate a local audio source in the link room but don't use that facility. I have Avant 32 DVD>1611>BC9500>MCL>Xtra TV>LX5500 and it all works well. (why change it??) I would use the Avant in the link room with a BV7 (or BV10) as master but retaining the MCL as it would be difficult to re-wire.
Ok. If you can set the Avant to V.OPT 6 it should work. So I would check it out. Good luck.
Thanks Carolpa & Stefan for the helpful replies.
