Hi all,
I'm evaluating to buy BeoSystem3 + center speaker + LCD screen (if possible... I found only plasma ones referred as compatible) or go direclty with a BV7-40 (woth no BlueRay built in) and B&O central speaker.
Can anyone report about differences betweek BV7-40 mk4 and BeoSystem3, by a sound/video processing point of view and overall usage benefits or pitfalls?
In addition... would you evaluate an used BV7-40 mk3 or the mk4 is clearly better to avoid the used one completely?
Thanks,
Raffaele "SKApretto n.71" Sgherri
I like Chrome and spread it!
