Hello out there
I brought a defective MX4000 MKII type 3334 from 1995.
The lady i brought it from told me, that suddenly one day when she wathced television, black smoke went out of it, and she turned it off.
I expected it was due to some exploded capacitors or resistors, but i can se the connector on the picture tube have a burned print circuit line.
I wondered this was due to bad connection between the connector and the pcb? or maybe a shorted deflection coil?
Onfortunatly i havnt tested the resonance of the deflection coil yet, i need to borrow a function generator
Have you seen this before?
Regards Thomas
