Latest post 04-04-2010 5:56 PM by joeyboygolf. 5 replies.
Page 1 of 1 (6 items)
  • 04-03-2010 5:47 PM
    Which Beogram is compatible?
    Hi i was wondering if you could help me. I have Beolab 4500 speakers and beosystem 2500 and would like to know which Beogram would be compatible with them without having to buy a pre-amplifier.
    Thank you for your help
    Andy
  • 04-03-2010 11:28 PM In reply to
    • BeoTom
    • Not Ranked
    • Joined on 02-09-2010
    • Texas
    • Posts 45
    Re: Which Beogram is compatible?
    Hey Andy,
    Nice system!  I've always admired the Beolab 4500's.  The two Beograms, with built in pre-amps, that will work with your system are the Beogram 7000 and 4500.
    Tommy
    Edit: Sorry, forgot to add the Beogram 6500 as well.  If your not familiar with these tables, they are all essentially "mechanically" the same turntable (tangential).  They really vary only in cosmetics, with the 4500 table matching the rest of the Beosystem 4500, and the 6500 and 7000 matching the Beosystems 6500 and 7000 respectively.
  • 04-04-2010 2:55 AM In reply to
    You also forgot the Beogram 3500...........and the older Beogram 6000 CD4.
    So, in a nutshell, you want Beogram 3500, 4500, 6500 or 7000 from the more modern series of tangentials or Beogram 6000 from the older models although these are quite rare.
    Regards Graham
  • 04-04-2010 2:18 PM In reply to
    Hi I got a mint Beogram 3500 and about to hook it up to a Beocenter 2, via a cable from Steve at SoundHeavenly for £20.
    this is my setup in my loft room
    http://www.sensotronic.co.uk/images/DSC01139.JPG
    Jon
  • 04-04-2010 5:27 PM In reply to
    • BeoTom
    • Not Ranked
    • Texas
    • Posts 45
    joeyboygolf:
    Yes, you are right.  Thanks for adding those Graham!
  • 04-04-2010 5:56 PM In reply to
    There are other more esoteric Beograms and you can read all about them here
    http://www.beoworld.org/article_view.asp?id=67
    Regards Graham
